Guys, i just got my Seagate Desktop HDD.15 4TB 64MB SATA-3 3.5" Internal Hard Disk Drive ST4000DM000
I'm moving all my data from my old HDD and the speed is about 60 - 80 MB/s
Is there any way in which i can increase the hard drive speed of transfer?
Thank you a lot
My specs are as follows :
my specs are as follows
MSI GTX 770 Twin Frozer 2 GB  graphic card
Thermaltake S21 case
TX650M power supply
Seagate 4 TB HDD
Samsung evo 840 1 TB SSD  ( STILL ON SHIP LOL)
CORSAIR Dominator platinum 16 gb Ram
Current system build :
Samsung Evo 840 1 TB , Seagate Desktop HDD.15 4TB 64MB SATA-3 3.5" Internal Hard Disk Drive ST4000DM000 , corsair dominator platinum 16 GB , Msi GD65 Gaming , Intel Core I5 Processor 4670K@3.4Ghz , Thermaltake S21 , MSI GTX770 Twin Frozer Graphic Card , Corsair Tx650M PSU
https://linustechtips.com/topic/151171-hard-drive-speed-seagate/
The transfer speed will depend (among other things) on how
large the files are which you are moving around. The smaller
the files, the slower the transfer speed. For very small
sizes, speeds can drop down to a few megabytes/s.
For mixed data (which I'm assuming is what you're moving
around), your speeds sound about right. If all you're moving
are very large media files (say, a few gigabytes in size
each), it could be higher, but for "normal" files this
doesn't sound that unreasonable.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/151171-hard-drive-speed-seagate/#findComment-2019368
You are bound to the speed of the slow drive in this case and motherboard ports you have that drive and the new one. Then you don't even list what the old drive is.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/151171-hard-drive-speed-seagate/#findComment-2020842
That's like a good speed.
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/151171-hard-drive-speed-seagate/#findComment-2020855
