Best way to re-attach the ear-cup (?) for a pair of sony headphones
Solved by OhYou_,
in many cases you can find someone who 3d prints and sells replacement parts for more common headphones, Barring that, I would also suggest epoxy, and buying a bit of raw fiberglass or carbon fiber to cut into little strips and stick within the epoxy and form a better joint.
you have to be careful to not affect the swivel of the joint in any way or it will then not fit on your head well and it gets extremely annoying.
