Power suply efficiency
Go to solution Solved by Spotty,
16 minutes ago, Andrusa said:
I was wondering, is there a big difference between no 80+ rating and a basic one, like bronze or silver? Is it worth it to upgrade the power supply to one with these kinds of ratings?
The wikipedia page for 80+ has what efficiency level each of the different ratings are required to reach.
https://en.wikipedia.org/wiki/80_Plus#Efficiency_level_certifications
Whether it is worth it to replace a less efficient power supply with a more efficient power supply depends on how much power your computer consumes, how long the computer runs each day, how much your electricity costs, and the cost of a new power supply.
You can calculate how much it costs using the following formula:
(Power Draw (W) / Efficiency) * Hours * (Cost (kWh) / 1000) = Cost to run per day
For example
Your PC draws 150W on average with your use
You use it for 8 hours a day
Your electricity costs 30c/kW
Your PSU is 80+ Standard (let's say 80% efficient at the 150W load)
(150W / 0.8) * 8 * (0.30/1000) = $0.45 to run per day ($164 per year)
If you swap for a more efficient 80+ Gold PSU that is 90% efficient.
(150W / 0.9) * 8 * (0.30/1000) = $0.40 to run per day ($146 per year)
In that example you would save $18 per year in power cost by swapping to a more efficient 80+ Gold power supply. Over a period of 5 years that might add up enough to justify the cost of a new power supply.
If your system uses more power, you run the PC for longer, or your electricity costs are higher then the savings would be much more. Inversely if you use your computer less, it doesn't draw as much power, or your electricity cost is cheaper then it might not be worth the cost to upgrade to a more efficient power supply.
I have a Corsair VS650 (old version, 5 years since I bought itScreenshot_20230606_110223_eMAG.thumb.jpg.7c726a84dfcb470d10cf19dbbabb85ae.jpg, I have seen a new one where the writing is white and has an 80+ bronze rating, mine has none). I was wondering, is there a big difference between no 80+ rating and a basic one, like bronze or silver? Is it worth it to upgrade the power supply to one with these kinds of ratings?
https://linustechtips.com/topic/1511384-power-suply-efficiency/
If your current one is working well enough then no. But efficiency could be more useful in Europe where the energy prices are higher. I would say as a rule of thumb to always get at least an 80+ rating (doesn't need to be bronze) but at least 80+
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1511384-power-suply-efficiency/#findComment-15973261
No not really especially when nowadays everyone and their mother who have enough cash to go to 80plus can just get it with the most subpar built PSU in the world.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1511384-power-suply-efficiency/#findComment-15973265
For example
https://linustechtips.com/topic/1511384-power-suply-efficiency/#findComment-15973270
For example
alright thanks man, this helped me a ton!
https://linustechtips.com/topic/1511384-power-suply-efficiency/#findComment-15973276
