Mysterious PNY 1060 3GB. Help me fix it?
Ykcud
First off, I am very well aware that this card is not exactly a powerhouse, but I still want to try and fix it.
I seem to have an elusive PNY 1060 3GB GPU on my hands. It has some stability issues. I want to try and flash the correct BIOS onto it.
However, I am not able to find any info on it anywhere. I looked up the part number in my browser, searched eBay for listings of it (both for sale and sold) and searched on techpowerup. The ladder only shows 6 GB models from PNY.
There is a 3 GB model of the GTX 1060 out there, but it has two fans and the one I have just has a single fan in the middle (as you can see from the pictures below).
The part number of the GPU is “gmx1060n3h3es1ktp6bjc”.
It was given to me for free, so if I can’t fix it, it’s not the biggest issue or anything, but I still want to try.
Also, I am hoping I don't have to contact PNY to see if they will give me a BIOS file. This is because in the past whenever I asked for a BIOS file from a brand, they declined to provide one, and I asked a lot of them. Not a single one provided a file.
If I can get it fixed, I am thinking I will give it to my best friend’s daughter. She currently has a GTX 760 in her rig and from what I can find, the GTX 1060 3 GB is about 2 times as good in terms of gaming. It would be paired with an FX 8350 as that is what is in her PC.
Anyone able to shed some light on this particular card?
GeForce GTX 1060 3GB (pny.com)
also i think you shed plenty of light on the card (left side)
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
Oh lol. I guess I did. Thanks for providing that link by the way.
no worries, in the download section there isnt a bios but im currently looking for one, one sec
Setup:
Any chance anyone knows where to get the right BIOS for this card?
Oh sorry, I sent my last response before I was aware you were looking for a BIOS. Much appreciated by the way!
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
VGA Bios Collection: PNY GTX 1060 3GB 3 GB | TechPowerUp
closest thing
im pretty sure all these PNY cards use the same vbios
Setup:
2 minutes ago, DoctorNick said:
i dont think its good to get it from another manufacturer, i sent the link to another pny card with same specs, probably use the same vbios file across all versions of the pny gpus, better to do that then risk another custom vbios from another manufacturer
Setup:
I wouldn't flash unverified BIOS files. Also reference design is reference, you know. The PNY BIOS has same clocks as the original card and support all memory brands
FS in Denmark/EU:
Hmmmm. I kind of agree with both of you. Though I am leaning toward the unverified one, but I think I am going to give this a bit more time to see if anyone is able to locate another BIOS for this card.
