Looking for a compact case to house these parts
G9XFTW
Go to solution Solved by SorryBella,
1 hour ago, G9XFTW said:
ak520
You mean the AK500? Sorry moot point but i cant help but to notice.
3 internal drives including one hdd
2 hours ago, G9XFTW said:
it has optical drive bays and the front hdd cage which I suppose could be done without only if I can move the storage elsewhere. I think modern cases have those options.
so 2 SSD and 1 HDD, and you need 5.25? Im doing both no 5.25 and with 5.25 to split hair.
I want a smaller case than my current Corsair 400R.
Dimensions (521mm x 206mm x 503mm)
No dimensional constrain? Ill use the liter to signify compactness then.
Reference
400R: 53L
ATX
Fractal Design Pop Air: 46L (-7)
275R Airflow (no 5.25): 44L (-9)
SSUPD Meshroom S (hard to find, and its compact build so youll have a hard time building with ATX non modular PSU and youll need new low profile cooler): 15L (-38)
mATX
Fractal Design Focus G Mini: 36L (-17)
Fractal Design Pop Air Mini: 36L (-17)
Masterbox NR400 with ODD (there's also no 5.25 version with 1 extra fan mount): 35L (-18)
Asus Prime AP201 (no 5.25): 33L (-20)
Fractal Design Meshify 2 Mini (no 5.25): 32L (-21)
I'm looking for suggestions.
Full size atx motherboard.
Deepcool ak520 cooler
rx5700xt
full size atx power supply
3 internal drives including one hdd.
A small footprint is very important for me.
rx5700xt
you could try this fractal north Fractal Design North ATX Mid Tower Case (FD-C-NOR1C-03) - PCPartPicker
Mark the solution as solution
Take my advice with a grain of salt. Not too much tho, we don’t want ourselves getting dehydrated do we?
PC Specs: Black on white, Team Red+Green by Filpo - AMD Ryzen 5 5600, GeForce RTX 3060 12GB, Corsair 4000D Airflow ATX Mid Tower - PCPartPicker
CPU: R5 5600 CPU Cooler: Arctic Liquid Freezer ii 280 Mobo: B550 Gaming Plus RAM: 2 x 8 3200mhz LPX  SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB GPU: MSI RTX 3060 Gaming X Case: 4000D airflow Fans: 2x Noctua P12 redux 1700, 1x Arctic P12, 1x Corsair LL120 PSU: RM850 Monitor: Samsung C22F Mouse: Logitech G203 Keyboard: Royal Kludge RK61
Two reasons to why you’ve scrolled down here 1. You’re curious 2. I’ve got a stalker 👀
ak520
Reference
400R: 53L
ATX
mATX
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
