I recently finished a new build with a Ryzen 5 5600 (using the stock cooler), but I noticed while changing something in the BIOS that my CPU temps were at 66°, is this normal for this CPU and Cooler combo? I know the stock cooler isn't fantastic but this still feels a little too high!
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/
66c at BIOS ? that's hot.
What is your PC case ?
Refresh before you reply
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/#findComment-15957833
15 minutes ago, ryzen55600fan said:
I'm using an NZXT H510!
H510 Flow?? H510 Elite? Normal H510??  Be more specific 😂
If you by some reason don't know, just take a pic of the front of the PC case.
Also, try tightening the CPU Cooler's screw, just don't go ham at it.
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/#findComment-15957858
8 minutes ago, ryzen55600fan said:
Just the base model, I'll give tightening it a go!
base model means standard H510 with closed off front then.
If so, then also try opening your side panel and see if it helps a lot. (if tightening screws doesn't help much)
If it does, then most likely you have an airflow issue sir.
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/#findComment-15957869
Turns out I completely forgot to tighten the top left screw LOL
Temps are hovering around 50° in windows with the side panel on now!
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/#findComment-15957878
Well, that's much better.
Probably won't get much lower due to airflow constraint because of PC case & cooler's passive heat sinking capability.
https://linustechtips.com/topic/1509276-ryzen-5-5600-temps/#findComment-15957886
