CSGO frame drops please help me
Solved by Sima01,
CSGO itself benefits from the single core speed as far as I remember, don't quote me on this one, I doubt it has something to do with the GPU, 83 is little bit higher to be honest, but I can't give you an precise answer on why do you get those lows. Try lowering your RAM speed, try lowering your XMP profile, just because you can switch to it doesn't mean its stable. You could reinstall CSGO or just put fresh install of Windows on your PC. I have Gainward dual fan 3060 ti and I didn't notice that high temps as far as I remember.
