I'll be mostly use this system for gaming.This is my components:
Case : Cooler master Elite K380
CPU : intel Core i5-4670K
CPU Cooler : Coolermaster hyper 212 X
Motherboard : MSI Z87-G45 GAMING
Ram : 8GB G.SKILL Ripjaws X
GPU : msi gtx 750ti
Disk Drive : LG GH24NS95
Wifi card : TP LINK WN722N
PSU:?
Questions:
1)Will these components fit inside the case?
2)What is the ideal power supply for gaming and for future upgrades?
https://linustechtips.com/topic/150787-power-supply-help/
I used the power supply calculator, and it tells me on full peak load 100%, you'll need 265 watts. Recommended 315 watts. The Corsair CX430M is perfect for your build. It's got a little too much, but that's fine because at any time you can upgrade your 750 Ti.
http://pcpartpicker.com/part/corsair-power-supply-cx430m It's also semi-modular so you can choose which cables you need and throw the rest of them in the box. 80+ Bronze keeps it at at least 82% efficiency.
http://extreme.outervision.com/psucalculatorlite.jsp
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014229
Everything should fit in fine. A nice Corsair or Seasonic 650 or 750 watt PSU would be great (allowing room for a good amount of overclocking and upgrading to something like a 780Ti).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014232
There's no way he'll be upgrading to a GTX 780 Ti by looking at his entire build. Going from a $150 card to a $700 card doesn't make any sense. It's also a horrible idea to plan to upgrade to a much better card in the future can having to use twice the amount of power that you'll ever need. He'll be spending a lot of unnecessary money on his power bill and his computer will be hotter than it'll need to be.
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014288
How do you know that he won't? He has a great CPU and motherboard. He might not have had enough money for a new GPU, or he wanted to have one long enough to save up for a really nice one. And the OP even said that he might upgrade sometime in the future.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014307
I agree with him go with a 650 to 750 watt power supply so you have a nice amount of leg room for upgrading and overclocking.
current build and total cost   http://linustechtips.com/main/topic/150083-thrift-shop-build/
I apologize for my crappy English I'm American
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014351
750W is OVERKILL for his rig, 500W if more than enough. But if you want some space go for the same PSU I have in my sig. It's great plus it's gold efficiency.
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014394
ok 750 watts is overkill but you want him to get a 1500watt one?
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014422
Exactly. And he can worry about his power supply when he wants to upgrade.
read his post he says if he is to get a bigger power supply than needed to get the one in his sig...and the one in his sig is a Vengeance 1500V2
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014456
Same as what I'm doing I had some blackmarket shit PSU and decided I'm going to get a 770 soon so I got a new PSU. It makes sense...
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014460
Sorry but you are an idiot, the Vengeance is my headset. The supernova nex650g is my PSU
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014467
No need for the harsh words I simply overlooked that as it isn't a big brand (atleast not one that I have heard of)
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014489
What Corsair Vengeance or EVGA lol
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014502
That's Corsair! What are you even talking about?
1. There is no power supply names Vengeance and;
2. There is no headset called Vengeance. Just the model name from Corsair.
Just use your common sense. A GT610 would never require 1500W.
A 650W would make much more sense and he has an i5.
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014506
I've never heard of Supernova not a big fan of EVGA so I guess I never really pay much attention to them
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014534
Plus getting a EVGA GTX 770 2GB ACX..
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014540
Awesome. Perfect power supply for you upgrade. I have very similar, just look at my sig. My power supply is the Corsair TX650M, althought it's 80+ Bronze, the components in the PSU are high quality and dual-ball fan bearing.
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014555
Sweet rig man, hows that cooler? You managing good overclocks, I was thinking of getting H80 after I upgrade mobo and cpu later this year, but unfortunately the H100 doesn't fit the 300R D: Maybe you could help me out as I'm in the middle of writing up a build log and looks for people to help me choose parts! I like yo keyboard :$
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014586
Great cooler for a 120mm radiator. I'm not overclocking yet, I just built it yesterday and I'm going to vacation for 3 days, so I will barely be on LTT. After I come back though, I'll definitely help you on your build log!
And yes, my Ducky MX Blue's are amazing.  :lol:
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2014603
Awesome, sorry ran out of data at my nans and yea thanks dude!
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/150787-power-supply-help/#findComment-2015619
