I am trying to play with my friends on Monopoly Plus, but when I create a game, it says, "Your NAT Type is strict, so you cannot host an online match. Please check your NAT settings and try again." I have searched the issue on Youtube, Reddit, and the Ubi forums, and nothing has helped, and port forwarding is not an option. I can refund the game if this issue isn't fixable.
https://linustechtips.com/topic/1507117-monopoly-plus-nat-strict-fix/
If restarting your network adapter doesnt help then youre most likely SOL and its an ISP setting. You can try to negotiate about it with the customer service but most likely scenario is that theyll deny you due to either technical or security issue.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I have tried the video above, and my ISP has been reliable between two houses for over four years. This has been the only time it's happened in a game. I can try talking to ISP, but they most likely won't help much. I have reinstalled drivers, tried ethernet and WIFI, and am debating refunding. I want to play it, but it seems like it's not worth it with this issue. I can provide videos if needed to get more context if it helps, but it seems like it can be an Ubi thing too.
