My first build - Recommendations?
Solved by WallacEngineering,
1 minute ago, B.techno said:Ok thank you guys for the corrections, so changing to the Ryzen 5 5600 and a simpler 120mm cooler.
This left me with more cash for the GPU. So I found this:
an RX 6600 XT Challenger D 8G OC ASRock AMD Radeon, 8GB GDDR6, RDNA, Ray Tracing for R$2210
That would still fit budget making my total R$5855 + shipping.
Would this make sense or would I now be spending too much on GPU?
It makes perfect sense. The 6600-XT GPU pairs perfectly with the Ryzen 5600.
