merging audio signals
Go to solution Solved by Heats with Nvidia,
There are basically 2 ways to do this easy. Either you use a switch that has only one active position like a rotary switch, or you add a resistor in series to every input (10K Ohms should work) and build a passive mixer.
hey,
building a simple guitar pedal sized audio "merger" for some synths, with 2 pole on-off-on switches. 4 inputs, 1 output. main purpose to have 1 switch ON and 3 OFF to not have to rewire to use the effect chain.
this seems to work fine with the un-soldered test i made, but i mean i don't know shit...
1. when used with only 1 swtich ON, is it ok to just wire this without any other parts ?
2. maybe i want to have 2 or more switches ON at some points, is audio signal merging a problem? i know splitting isn't obviously, but no idea about merging. my guess would be to use diodes in that case? i still have lots of spare parts..
https://linustechtips.com/topic/1505017-merging-audio-signals/
https://linustechtips.com/topic/1505017-merging-audio-signals/#findComment-15925366
basically this ? https://electronics.stackexchange.com/a/136134
will this work with 4 inputs?
and as far as i understand, a rotary switch will work the same way as 4 2 pole switches if only 1 switch is ON.
thanks, will try it with resistors
https://linustechtips.com/topic/1505017-merging-audio-signals/#findComment-15925419
Yes. 🙂 And you are welcome.
https://linustechtips.com/topic/1505017-merging-audio-signals/#findComment-15926995
