Best multi-condition smart home trigger ecosystem (GHome, Alexa, Smarthings)
Solved by BiotechBen,
1 hour ago, SpeedBird999 said:My problem is that two different routines (one "when X device leaves, turn off", two "when Y hour, turn on") don't talk to each other.
I cannot add more "triggers" to a single routine apparently, if there's a time as a trigger you can't also add position.
Just tried this setup with time, and it worked, so should work as well for "at sunset" and with "away" instead of home.
