I need some troubleshooting on my pc.. ive been having some issues on my 5600g and rx 6700 xt.
when i play AAA games my pc runs fine. but when i play valorant my fps drops hard. usally my fps is around 300 - 100 fps but recently it dropped to 80 fps. what could be the problem?
side note: also notice my cpu running at max frequency and even higher in task manager but when i check adrenalin software its only at 3.2. it this a problem?
https://linustechtips.com/topic/1504013-5600g-with-rx-6700xt-problem/
6 minutes ago, Agent Lou said:
i havent updated my bios cause everything is running
I would install a fan in the back and also update the bios... The VRM seems to be quite bad but I wouldn't have thought that a 5600G would be to much for it, so there might be a bug
okay okay ill try to update my bios. thanks for the info ill try to update it it worked 🙂 tnx
  • 1 month later...
