cat5e can do 1Gb/s up to 100m
cat6 can do 10Gb/s up to 100m
if its for in wall, id do cat6 just for some future proofing.
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2008732
But will I notice a difference as far as gaming with my Rogers router? I'm currently using a CAT6 50ft ethernet cable and it runs fine.
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2008763
So I'm debating weather to get Cat5e 100ft in two days with Amazon Prime or Cat6 75ft from a retailer on Amazon in 7-11 days. Is ethernet cable speed dependent on your router? How does this work, thanks in advance for any help you guys can give me.
this video is about rj45 but may help u in case of speeds... :)
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2008791
no you wont. 1Gb is more than any connection you can get to your isp, so CAT5e is plenty for that, but if you have a nas, its nice to know you can upgrade to 10Gb without too much hassle later
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2008794
Obviously the NAS itself needs to support 10GB ethernet too, which most don't without installing a dedicated card if it's a proper PC, or being really really expensive if it's a prebuilt small one.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2009121
Key word being "in the future" :P
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2009137
That doesnt sound lik the future :P
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2009266
^ This
However, cat5e can still do 10Gb/s for up to around 55m (Ideally keeping it a little shorter as it may not be exactly 55m - it depends on several environmental/interference factors as well).
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/150325-ethernet-cable-speed/#findComment-2012531
