Help setting up multiple displays with two computers
Solved by OhYou_,
what model is the work laptop
if it is a thinkpad, you should get a thinkpad dock as it will provide you two displayport outputs.
i advise against display port switches but if company is buying then go for that.
otherwise i suggest using a second display input on the monitor for the laptop and hopefully it has auto switch.
There is software you can use to disable the two displays on the desktop so that autoswitch will switch off to the laptop
