Can more fans at the top of the case decrease gpu temps?
Currently I have high junction temps on my gpu and if push hard, it can crash. Normally it is not a problem but I like overclocking. I have a Lian li Mesh case with 2 intake fans on the front, and 1 exhaust on the back of the case. Gpu temps decrease when I open the case window. So I wonder, if I put 2 or 3 fans at the top of the case or buy an AIO cpu cooler set at the top, can I lower my gpu temps? Gpu fans are looking downwards, so cooling the top of the gpu should be a god thing right? Any insights?
I mean as long as you have the fan set to blow cool air into the top of the GPU then exhaust out the bottom it logically should help with your temps.
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
But since heat rises, wouldn't the opposite of what you suggest be better.  Put your intake fans at the bottom or front of the case so they can pull in fresh cool air and then put your exhaust fans at the top of the case so they can pull the hot air from the cpu/gpu and blow it out the top of the case.  Also leave the fan on the back of the case blowing out.
i've found that with front-to-back airflow it might help a tad to have a fan at 45° angle at the front of the GPU to just "motivate" more air towards and past the GPU.
past that.. IMO front in and top out is mostly a recipe for wasted potential, if you're not in the "front and top rad" sort of position.
Placement has different effects depending on the case, components and cooling. The best thing to do is put fans in different configurations and see what happens. If you don't have extra fans, get some cheap ones but keep in mind that for places with a significant barrier (mesh,  rad, layers) you'll need to buy fans with high static pressure.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
for best gpu temps you want bottom intake and you need the back fan and posably the top back fan for exhaust. if you dont then the gpu exhaust hits the side and some gets re sucked back thow the gpu. some case can make a hot pocket at the bottom there.
the problem is the gpu exhausting its heat out the sides and hitting the side pannal and some back at the mb witch can have problem with some chipsset cooling.
since all case are tempered glass theres no side intake anymore. so a bottom intake case is best for gpus you can do.
as for cpu tower coolers front fans intake and some times the top front fan intake.
for aio front intake will make the gpu a bit hotter but cpu a bit cooler and top mount gpu cooler and cpu bit warmer. like 2-3c
