Hello
I saw LTT video in getting an arc as a secound gpu. It seemed like a fun challenge and i stream so it could nice to get the AV1 encoding before others. I didnt see any recent posts about it so i started a new one.
It starts up i see the log in screen and then it displays nothing.
i have my AMD 6950 XT as my primary gpu in my pcie 5.0 slot (z690 aorus ultra motherboard).
[other parts incase they matter ddr5 6000mhz ram, 12700KF cpu, arc in pcie 3.0 slot 2 (of 3), RM1200x shift power supply].
Has anyone else gotten this set up to work?
https://linustechtips.com/topic/1501916-6950-xt-a380-not-fully-posting/
On 4/19/2023 at 11:46 PM, JLssg4 said:
Two half-baked ideas to throw at you:
Did LTT use Windows OS?
Checked all the other display outputs when the initial one goes blank?
Yes he used windows.
I tried it again and it just worked. I had it open the bios to make sure it detected it first and the had it load like normal.
