Need Suggestions for a Gaming Monitor
Gessler555
I'm looking for a 32" 4K panel with 144hz or above refresh rate, HDR & G-Sync. Not interested in curved displays. Something in the price range of the Samsung Odyssey G7 would be great. I'm not particular about panel type, though I'm coming from an IPS for what it's worth.
Bring on the suggestions.
Intel i7-4790k | MSI GTX 1080Ti Gaming | MSI Z97 Gaming 7 | Corsair Vengeance 16GB (2x8) 1866mhz RAM | Corsair H80i v1 AIO | Corsair RM850x PSU | Cooler Master HAF 912 case | Asus VZ27AQ 1440p 75hz monitor | Samsung 840 EVO 120GB SSD | Samsung 860 EVO 1TB SSD | Seagate Barracuda 2TB 7200rpm HDD
https://pcpartpicker.com/
They don't have all local currencies covered, but it'll give you an idea what's available.
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
With your GPU and CPU can your computer push the pixels required for a monitor of this caliber
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
Youre kinda stuck at Dell G3223Q or MSI MPG321UQR-QD, there's not a lot of good option at sub 1K USD for 4K144.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
A GTX1080ti will just about handle 1440p/144... 4K is a non-starter.
4K/144 is going to need the likes of a 30- or 4080 or better.
WHY NOT...?!
if you really want it here u go image.thumb.png.cf9aec9674da5af98df71eb66edf7e0a.png
It's for a new build.
i7-13700K and 4090
i7-13700K and 4090
With that you should be fine. I just didnt want you wasting money on something you could not use nearly the full potential.
