PSU headroom for GPU power fluctuations?
Solved by Fred Castellum,
Admittedly I'm not necessarily looking at a 290x, but I wonder if there is a rule of thumb for how much overhead per GPU is needed to prevent power protection circuitry from kicking in.
E.g. if I was running at 90% of my PSU's rated capacity with dual graphics cards (PSU chosen based on average CPU and GPU(s) power consumption), could these power spikes cause problems if they caused the output of the PSU to be higher than its specified maximum load, even if just for a little while?
If I remember correctly the recommended overheard per GPU was around 75 watts each but its been while so I may be wrong.
