Can I use Corsair RM750x (2021) CP-9020199-NA to power an RTX 4080?
BotVE
Posted (edited)
I'm planning to upgrade my GPU, but my PSU only has four 8-pin connectors. Two of them are being used for my CPU and the other two for my current GPU. The 4080 requires three 8-pin connectors, so my plan is to use one PCIe cable to connect two ports. My current CPU is a 13600K, and I've applied some voltage offset, so it only takes around 140 watts(Aida64 CPU+FPU stress). I'm think PSU can handle it, but I'm worried about the cable.
Update: Change of the plan. I am going for 4090. Will this PSU able to handle it?
Edited by BotVE
Remove 1 of the CPU cables and add a third PCIe cable then. Just make sure it's a Corsair Type 4 Cable and NOT something else. If you don't have one on-hand they can be purchased from places like CableMod or from Corsair directly.
A single 8-pin EPS CPU Cable is rated for ~235W so it should be fine even with the not so efficient 13th Gen.
Or, for a cleaner look get a Corsair 600W PCIe 5.0 12VHPWR Type-4 PSU Power Cable instead and you'll have a cleaner build and not have to use the dongle.-base-CP-8920284-Gallery-PCIe-5-12VHPWR-PSU-Cable-Type4-01.png_1200Wx1200H
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Gigabyte Aorus ax570 Master; Ryzen 9 5900x;EVGA 280 CLC; 4 x 16GB DDR4-3200; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 4 x 3TB NAS; AMD RadeonPro W4100; EVGA RTX 3070 Gaming; Corsair TX650M
nas1: Fractal Define R4; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB SSD; 7 x 3TB Seagate NAS; Corsair TX450
nas2: Synology DS-123j; 2 x WD Red Plus 6TB NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; EVGA 240 CLC; 4 x 32GB DDR4-3200; 512GB NVMe; EVGA RTX 3080; EVGA RTX 3080 FTW3; Corsair TX750M
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; EVGA RTX 3080; Asus Tuf RTX3070ti; Corsair RM750x
dcn10: Mining Frame; Gigabyte Aorus ax570 Pro WiFi; Ryzen 9 5900x; AMD Wraith Spire; 2 x 16GB DDR4-3200; 128GB NVMe; 5 x EVGA RTX 2070 Super XC Hybrid; EVGA RTX 2070A; 2 x Corsair RM750x
dcn11: Fractal Define C; Zotac 4070ti; Gigabyte x570 Gaming-X; Ryzen 7 2700x; Coolmaster Hyper 212 e/w NF-F12 iPPC 2000; 2 x 8GB DDR4-3200; 64GB SSD; Corsair TX650m
That's fine. Corsair use high quality cables and connectors. Each daisy chained cable is rated for at least 360w.
buy the direct-to-12-pin cable from corsair, and you should be good.
