So im bored. this is what imma do:
1. get this: http://www.ebay.com/itm/AUDIA-Silver-Aluminum-Briefcase-Business-Locking-Brief-case-Organizer-Metal-/191158575565
2. Cut out IO port slot/and cpu air shroud intake (also a 80mm mount for a exaust)
3. cut gpu io port, and install
4. Mount PSU and HDD/SSD (im thinking a SSD might be a better choice for this scenario)
5. Mount/install ram, CPU, connect power.
6. make mount for one of those tablet like looking monitors that NCIX reviewed on the side of the briefcase.
7. Game.
Im doing this because i am done with laptops, and i want something that i can carry with a handle and be a bit more rugged. U guys have any thoughts or suggestions? I am going to be using a mATX board (itx stuff is expensive) with a wifi card. I need a cold cpu, so maybe some of the low end FX stuff, or a i3?
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/149784-lan-machine-in-a-briefcase-xd/
I've seen "laptop" conversions of game consoles with the same concept, those came out pretty cool actually.
Those were console conversions, for a PC, you're going to want to make sure you have proper ventilation and that the hardware itself sipping little power to produce the least of mount of heat. Maybe something like a low profile cpu cooler, a CPU under 100w TDP, a slim GTX 750 ti since 60w and definitely use SSDs for heat reasons as well.
im going apu+crappy gpu, im not a hardcore gamer. mostly minecraft, which would run just fine off the apu anyways.
I think you'd be better off going Athlon 760k + GTX 750 Ti Otherwise, I dunno. The suitcase idea is neat, but if it's going to be an APU only...you'd be better off with that one Lian Li case or an APU based laptop.
My chibi pc itx build is in a lain li tu 200 you might be able to grab ideas from that.
