How to connect 4+4 CPU Power NZXT 1000W
Solved by Spotty,
12 minutes ago, CPlusPlus1408 said:Both sides of the second cable are 4+4,
They shouldn't be.
Is there text printed on the connector saying "PSU" or "CPU"? PSU is the side that goes in to the power supply and CPU is the side that plugs in to the motherboard.
Dat_One_Guy ·
thnbnnwll ·
Posted in Troubleshooting0 -
Vicarian ·
Posted in Build Logs0 -
Sambadtech ·
Posted in General Discussion4 -
JuicyMullet ·
Posted in New Builds and Planning6 -
Artem ilienko ·
Posted in New Builds and Planning2 -
5
19
