so currently i have a laptop set up in my living room to run my project but it seems silly having a £1000 worth of laptop sat there purely to watch films on my projector is there a wireless display or something that i can connect to my desktop (upstairs) that can output the hdmi into the projector? unable to run wires as the projector is in the living room and the pc is in the upstairs office? or if any one else has a better solution were so i can sell the laptop as i no longer need it at all now
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/1497300-wireless-display/
That technology never took off...
When you try to transmit video + audio data wirelessly, especially through walls/wood/concrete, there is data loss.
The latency will be high as well.
You'll have frames missing, audio packets missing, video + audio can go in and out sync...
Your best bet would be to stream it over WiFi or something...similar to a Google Chromecast.
Linus did some "wireless HDMI" testing before....
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1497300-wireless-display/#findComment-15867085
If you have no use for the £1000 laptop I'd sell it and buy a £200 old-ish PC that'll be sufficient as media player. A half decent wireless solution wouldn't really be cheaper and would be a lot more finicky.
Can get some of these hp/lenovo tiny SFFs for about that price.
F@H
GPD Win 2
https://linustechtips.com/topic/1497300-wireless-display/#findComment-15867682
