theres gotta be some artists out here, id just like some tips on drawing faces im always struggling having them looking odd or the face details are just poor. any youtube guides or anything are fine
Specs
https://linustechtips.com/topic/149730-tips-for-drawing-faces/
make sure they have noses, i forget that ALL THE TIME
Eclipse Version 3: i5 9600K | Asus Strix Z390| GTX 1070 | 16GB Kingston Beast | Samsung 840 EVO 500GB SSD [2] +WD Blue 1TB | NZXT H440 | EVGA 750 W | Dark Rock Pro 4| Beyerdynamic DT880 Premium
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001081
what matters a lot is the perspective of the face, you don't want to have conflicting angles of view or it will look like a picasso.
This is a good start when you want to make an outline for your face, you just change based on were the face is intended to.. well face.
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001082
You can always break out the ruler if you have a reference work, I did that with mine and the amount of time I had would determine how many measurements and plots I would make. I never bothered with the guideline nonsense for drawing faces.
If you spend a lot of time measuring a reference alone, you can get a pretty decent near mirror of the face. The only difficult part is getting the skull shape right.
Error: 410
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001107
The eyes are halfway between the top and bottom of the head.
nooooooooooooooooooooooooooooo........
Specs
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001112
But they are..
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001132
believe it or not, I actually drew this all by myself.
god damn it my school has it blocked so i cant load it :(
Specs
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001136
But they are..
i know i was just making a sarcastic remark because he was saying something that was pretty obvious :P
Specs
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001137
Don't worry, you aren't missing much. It was a horribly drawn image that I made when I was 11 and still reappears in my nightmares. It reminds me of the doodle-bob sponge-bob episode. It (my drawing) is actually ravishingly ugly.
//ccap
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001145
Wasn't obvious to me. I was pretty shocked. :) I actually thought they were 3/4 or something.
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001147
well that can be true depends on the persons head size if they have a larger forehead the eyes will appear lower
Specs
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001154
well that can be try depends on the persons head size if they have a larger forehead the eyes will appear lower
Forehead size is determined by hairline. You draw the hair after you draw the head. But yeah, it'd appear lower.
I'm not artist so correct me if I'm wrong.
† TTCF Member †
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001164
A book I read on drawing says that you should always start with guidelines. Similar to the images posted earlier, you need to establish a rough sketch of the face. Obviously everyone's faces have a nose, eyes, etc., and as far as I know they're on only one location. In a rough sketch you need to point out the most important parts, esp. how you'll orientate the face. You have to draw softly as well because if you mess up, it'll be a lot harder to erase bolder marks than lighter marks. You cannot add in details until you are confident everything is where it should be. You can also point out distinct features on the face as well so you add them later.
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001166
No, you're spot on. Both your tips have been very good, and a great beginners tip guide.
One thing most people execute incorrectly are the eyes. Whether they are executed incorrectly due to placement or size. They are 80% of the difference of whether it ends up looking human, or LinuSlick-specied. I believe they're called Linusapiens. Or maybe Slickanderthals..? Can't quite remember.
But yeah, focus on the eyes. They are almost exactly in the center. Use the guideline that @_ASSASSIN_ provided, and you'll be okay.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001183
Well, proportions-wise, the eyes are mid-way down the face. Between the eyes, you can fit another "eye" and fit one "eye" on each side of the face. The top of the ear would usually be parallel to the eyebrows while where it meets the skin, it'll be parallel to where the eyelids meet. The bottom of the ear would also be parallel to the bottom of the nose. Noses are usually about 3/4's down the face; where the eyes are, the other half of the face should be divided in half for the nose. The mouth would also be halfway between the end of the nose and the chin.
Also, you could look up tutorials on Youtube for stuff like this.
Also, treat the parts of the face as just shapes e.g. eyes are ovals, noses are triangles, mouths are flat diamonds, etc. Guidelines like stuff you'll see comic book artists help as well to give a perspective of the face.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2001350
where i learned to draw characters from start to finish
http://www.pinterest.com/characterdesigh/
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2004670
wait what?
i have some usefull links for all kind of art related stuff
google is full with random tutorials
i have gathered some of the best:
http://artofinca.com/links - check out tutorials like proko and the others
or here
http://www.fusroda.com/resources
great list with tutorials and resources -
or "google" and "find" Andrew Loomis Books,bridgman books, bammes and similar
>> www.artofinca.com << Star Citizen fan art post https://forums.robertsspaceindustries.com/discussion/116794/star-citizen-fan-art-by-artofinca
pilot: Inca Talmir  ships: Freelancer MIS, M50, ???  play-style: Team-play  groups: Military, Exploration, Special ops, Support, Bears.
https://linustechtips.com/topic/149730-tips-for-drawing-faces/#findComment-2007732
