Best monitor under £200 used predominantly for PS5
Hi guys,
I currently have an MSI G24C4 which unfortunately requires a new screen after being damaged. I am looking for some advice on a monitor that is under £200 and will do a good job of running PS5 content. Mainly used for Shooter and RPG games so something comfortable with both of these would be great.
As the name suggests, I am a total novice when it comes to tech so any advice would be greatly appreciated.
Thanks in advance.
This is a useful tool: https://www.productchart.co.uk/monitors/
It works best in UK and US where it can show prices, but even if your living else where it still allows you to see what is on the market.
Will the monitor only be used with a PS5? If so you probably want a 1080p or 1440p 120hz monitor.
Do you need/want the display to be a certain size?
I'm not an expert or a professional and I make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/d6GkD3
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screw Driver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
Thanks, I'll have a look.
Mostly it will be used for PS5 but I will be using it occasionally as a second screen for my laptop to work from. I'm not too fussed about the working aspect but I am bothered about the PS5 side of things.
https://www.amazon.co.uk/dp/B0BGC9VRJ9?tag=gnod-21&linkCode=ogi&th=1&psc=1
I like this one for shooters but I don't think the colour accuracy is amazing, so watch reviews.
He/Him
Sorry just noticed your extra questions...
I'm looking for something that is around 24 inches and ideally curved but doesn't have to be.
The screen I have currently is 144hz but not sure if that makes a massive difference for PS5 or not, I have seen some monitors have 144hz and 165hz options but not sure if it would make a difference using it with a console?
PS5 can output 1080p, 1440p, 4k. The first two can be done at 120hz but at 4k it will only do 60hz.
He/Him
Does it matter about HDMI 2.1 or not?
HDMI 1.3 supports 144hz@1080p and 75hz@1440p
HDMI 2.0 supports 240hz@1080p and 144hz@1440p
HDMI 2.1 is kinda overkill for a PS5
You could also get a HDMI to DP cable if needed
DP 1.2 supports 144hz@1440p
Or atleast that is my understanding...
He/Him
