RX 5500 XT Driver Crash Help
Go to solution Solved by cyberphy,
Turns out it's a Windows problem and installing Windows 10 1809 fixes the problem (like it's been very stable and no problems)
I'm having a problem with my MSI 5500 XT 8GB
The drivers keep crashing when my computer turns off the displays (sleep is disabled) Gaming works perfectly.
When the crash happens I get a blank screen or it will freeze on the lock screen and I am forced to use the reset button on the computer The error I Get Is "Display driver amdwddmg stopped responding and has successfully recovered."Capture.PNG.08397ad50630cfdd646cae00178d1c96.PNG
I've tried the pro driver but nothing seems to work (yes I have tried DDU and a fresh windows install and I tried a different card in my system and the I tried using a different and it does not have this problem)
System:
ASUS B85M-E
CPU Xeon E3-1225 V3
Ram 12GB DDR3 1600
GPU MSI RX 5500 XT Mech OC 8GB
3 Monitors (All of them are the same resolutions and refresh rate)
OS Windows 10 21H2
  • 1 month later...
