air or water cooling?
i'v never build a pc before and am wondering if water or air coolers are best to use in a workstation
noctua nh-d15 should be better than most aios if you dont mind a bit of size. the chromax.black version looks better than the brown and silver
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
yes but is water or air cooling best
I assume you want it to run for years without a worry, maybe a bit of cleaning every 6 months or a year, then get air cooling.
You'd have one thing less to worry about, it will run forever because it's all simple mechanical parts.
But, if you're going with 13900K, it won't be cooled with any air cooler, so a good AIO is a must. So the answer to your question is depending on your CPU.
And this is wrong, good 360mm AIOs especially 420mm would beat the best air cooler.
No air cooler could tame 13900K, but some AIOs could tame 13900K.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
"Best" is subjective. There's pros and cons to each. Reliability? Air cooling all the way. Raw performance? A big AIO will be the winner. It just depends on how much you prioritize one over the other, as well as what CPU you're putting it on.
Because most AIO's die within 5-7 years its better to get a NH-D15 for reliability. If the chip constantly thermal throttles then its possible to just underclock it and get almost the same proformance.
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
Is a good 280 AIO - as good as the Noctua nh-d15?
They're about the same, I have an NH-D15 and EKWB 280mm Elite I've recently tested on my 7950x3D. For the 7950x3D, the AIO was slightly better likely because the lower operating temperature of the loop than a heat pipe.
I was testing a theory, which was originally generated with my 5800x3D that the 3D v-cache CCD would benefit from the lower heat soak latency of a heat pipe that operates at saturation over a watercooling loop. Turns out my theory was wrong, and likely because those heat pipes operate at a higher temperature overall compared to the fluid in an AIO. Those heatpipes likely operate at +30C comparably, and with our friend Q= mc|T-T|, it wasn't worth it. I saw lower MAXIMUM temperatures with the AIO for the same boost clocks, but steady state temps were the same.
The NH-D15 with dual 140mm fans and its towers is basically the same heatsink capacity as a 280mm radiator with dual 140mm fans. Unless you're talking a 3D v-cache CPU, I'd say its a toss. AIOs will operate at lower RPMs since it can more efficiently dissipate the heat and require less ramp with the higher specific heat capacity of water, where a large air cooler won't dry out or have a pump failure over time, are cheaper, but generally noisier.
Ryzen 7950x3D PBO +200MHz / -15mV curve CPPC in 'prefer cache'
RTX 4090 @133%/+230/+1000
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
I prefer an AIO - with an air cooler available as a backup but it seems the horror stories with AIO are a lot less common nowadays?
They still happen, maybe a little less than super early AIOs but still not unheard of. Plus there's been a ton of recalls with them as of recently, MSI's AIOs for instance had the fluid building up and clogging the blocks, causing them to stop working prematurely.
air coolers are still the proven tech but aios are good if you dont mind getting a new one every few years for ~$200
@Bob__ is a w
I dunno, I've got some old Corsair H units pushing into the decade old territory and they're still working fine. And mine aren't lone examples, I've built a lot of systems over the years with 240 AIOs from various manufacturers and the failure rate is next to none. And this is a span from 2010 to now.
Sorry, but that 5-7 year argument doesn't really hold any water (🤣) without some hard proof to back it up. A good AIO can be just as reliable as a good air cooler if you're getting a good one. And an air cooler is just as susceptible to manufacturing defects as any AIO.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Monster: Athlon XP 2800+ @ 2.3GHz, Asus A7N8X, 2x1GB DDR400, ATi X850 XT AGP, WD 80GB Caviar (PATA), No-Name 700W PSU, Deepcool Tesseract
The Overclocker: Core2Extreme QX9650 @4.5GHz, EVGA 790i FTW Digital, 4x2GB HyperX DDR3 1800, Kingston 240GB SSD, Zotac 9800 GTX x2 SLI, Custom loop cooling
Depends, both are fine but water cooling you'll have to check on once in a while, air is set and forget until it's gets clogged with dust after a couple years 😃
Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - XFXRXXT
X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
That's from a design flaw - that's different.   I'm talking about normal operation - if it was manufactured well and has typical/normal operation.   Btw, why is the Arctic LF II /a-rgb 280 AIO in the Tier 2 list?   I object to that. 🙂    You can check YT videos and it is extremely close to the 360 AIO version in performance/noise/cooling etc.
