Budget (including currency): $2000ish
Country: USA
Games, programs or workloads that it will be used for: looking to play next gen games that are no longer being released on the Xbox one plus some steam games
Other details:
Currently don’t have a computer but using pcpartpicker.com I’ve formed these parts and was looking for a bit further input
CPU: Intel I7 13700kf
CPU cooler: Deepcool LS720
Motherboard: Asus PRIME Z790-P WIFI D4 ATX LGA1700
Memory: Corsair vengeance pro rbg 4x16gb ddr4 3600 cl18
storage: Samsung 980 Pro 2 TB (m.2) & Crucial MX500 2 TB (2.5in ssd)
GPU: MSI 3060
Case: Corsair 4000d
power supply: Corsair rm850x
ill be running windows 11 pro
this is the link to the parts I have picked https://pcpartpicker.com/list/qvk8GL
I’m wondering if there will be anything else I’ll need. This will be my first build and I’ve watched the ltt build guide but any input will be greatly appreciated
https://linustechtips.com/topic/1494989-first-pc-build/
If youre already utilizing PC Part Picker you can just copy your list through this field. Use the BBCode Markup for this forum (the BB button).image.thumb.png.c2da90d465af8f6933b103f6e6151af5.png
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1494989-first-pc-build/#findComment-15848872
You're way underspending on your GPU and overspending on most everywhere else.
https://pcpartpicker.com/list/RWssTn
Get that instead. It's still a little overkill, but it's still really fast. The 13600KF is about as much of a gaming CPU as you need, the cooler is plenty for that chip even if you're overclocking, the motherboard is good enough, the RAM is about as fast as I'd expect to just enable XMP, the storage config makes much more sense, and the PSU is a little cheaper but about as good (a bit more efficient as well). The big difference between these two systems are the GPUs, the 4070 Ti/7900 XT is over double the performance of a 3060, all within the same budget. There is debate over whether the 4070 Ti or the 7900 XT is the better option, the 4070 Ti is much more efficient and has better RT performance, while the 7900 XT has more VRAM and is 10% faster in more traditional rasterization games. I'll let you pick which of the two you want, they're the same price and both good options.
they included a link at the bottom of their post
https://linustechtips.com/topic/1494989-first-pc-build/#findComment-15848873
Thank you. I’ll definitely look into it. I was thinking about just forking out the money for the 4070 I’m still saving money for it so a few hundred more dollars to be a bit more overkill doesn’t seem to bad for me. I’ll definitely keep this in consideration
https://linustechtips.com/topic/1494989-first-pc-build/#findComment-15848884
If you're still saving money, come back once you're ready to buy it. Stuff changes so quickly in this space that realistically any recommendation won't be relevant for more than a week at most.
https://linustechtips.com/topic/1494989-first-pc-build/#findComment-15848885
I am blind as a mutt.
PCPartPicker Part List
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($209.94 @ Amazon)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($64.98 @ Amazon)
Motherboard: MSI MAG B660M BAZOOKA DDR4 Micro ATX LGA1700 Motherboard  ($129.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($37.49 @ Amazon)
Storage: Patriot Viper VPN110 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($112.99 @ Amazon)
Video Card: MSI VENTUS 3X OC GeForce RTX 4080 16 GB Video Card  ($1182.92 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Gigabyte UD850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($128.98 @ Newegg)
Total: $1962.28
Generated by PCPartPicker 2023-03-18 22:39 EDT-0400
This one is far heavier handed on GPU but @RONOTHAN## build is good if your game particularly LOVES cpu.
https://linustechtips.com/topic/1494989-first-pc-build/#findComment-15848887
