You don't need a CPU for an ASUS USB Flashback mobo
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
Download the proper bios, rename it, throw it on a USB stick and plug it into the specified port (only one works with flashback), and hold the flashback button on your board. An LED will start flashing slow, and flash faster and faster until it turns off. If the LED is solid, there was a mistake. When the flashing stops you should be good to go.
CPU:聽AMD RYZEN 7 3700x聽|聽CPU Cooler:聽AMD Wraith Prism聽|聽Motherboard:聽MSI MPG X570 Gaming Plus聽|聽Memory:聽Corsair Vengeance RGB Pro 16GB (2x8GB)聽|聽SSD:聽Samsung 970 Plus 250GB NVME, WD Blue 2TB m.2, Crucial M500 240GB|聽GPU:聽EVGA GTX 1080 FTW聽|聽PSU:聽Seasonic G-Series 550W聽|聽CASE:聽Corsair 220T RGB
https://linustechtips.com/topic/149298-help-with-flashing-bios/#findComment-1994550
no no. you can fix this, you bought a premo board after all..
go get the latest bios.cmo file
get a freashly formatted (fat 32) thumb drive
put that file in the root of the drive
plug er in to the bottom intel LAN usb port, should be circled green or something
take the cpu out
plug in the 24pin
push the flash button
better find a real guide..
https://linustechtips.com/topic/149298-help-with-flashing-bios/#findComment-1994558
take the cpu out
plug in the 24pin
I posted the real guide from the ASUS site above. ^
https://linustechtips.com/topic/149298-help-with-flashing-bios/#findComment-1994586
