Power cable question,
Basically, I think he means that it says on the AC cable (power cord) 120v and 10A or something like that, and he's in a country that uses 230v AC
The power supply accepts a wide range of input voltage, as it says on sticker, 100v - 240v, so the actual connector is designed to handle 240v and higher. No worries on the power supply side.
As for the power cable ... I'd say 90% sure it's gonna be fine.
Most likely they printed 120v 10A on the plug of the cable because they planned to sell it inside US and didn't want to confuse people with higher voltage printed on it.
The maximum current rating is defined by how thick the individual wires in the cable are ... so the cable is made with thick enough cables to handle 10A (10A x 120v = 1200w), no worries about that.
The maximum voltage rating is usually defined by how much spacing/clearance is between individual pins in the mains socket, the spacing between the contacts in the plug, maybe sometimes the quality of the metal used for contacts (how well they handle sparks from plugging in and out the plug)
As the plug and connector on power supply is standardized, IEC C13 (plug) and C14 (receptacle on psu) , they ends of the cable should handle more than 240v just fine.
So that leaves only one possible issue the cable may have but it's really unlikely .. the individual wires inside the cable may have a much thinner insulation compared to a 230v version of the cable, which could mean that at high currents (1000w+) the thinner insulation may become damaged and melt in some places along the cable.
But again, this is so unlikely I wouldn't worry about it.
It's much more likely a company making these AC cables buys miles of cable produced by other companies and just cuts the cable to length and installs plugs at the ends and stamps those ratings on plugs, and they'll use same cable on both 110v and 230v cables.
