Yesterday I was watching streaming media, and all of the sudden, the stream kept stopping.
When I opened on W11 Pro (version 22000.co_release.210604-1628 -- without a specific Firewall installed other than running the Windows one, and without VPN or any other network app) the Task Manager // Performance // Ethernet there was a lot of S (sent) traffic occouring.
I immediately Disabled the Ethernet device and tried to figure out what was happening.
When I got to Resource Monitor // Network I didn't find any odd app running or TCP connections established, even after I Enabled the Ethernet device.
IDK wut the F was going on, but I'm somewhat protected ATM, on a new W11 install.
My request is:
- Which is the best Open Source Network Tool to monitor and log inbound and outbound traffic in general ways, but also, to be able to understand 1 by 1 which app does what?
Thanks in advance.
Take care, and take care of somebody else.
George Carlin: Jammin' in New York 1992
https://linustechtips.com/topic/1492215-need-network-traffic-tool-able-to/
To do detailed analysis, you could try Wireshark, though it's not necessarily easy to understand if you don't know your way around network traffic.
For a quick overview, you could try something like Glasswire, https://www.glasswire.com/ though Resource Monitor should already be able to show the source of incoming and outgoing traffic
15 hours ago, Falcon1986 said:
And this couldn't be due to Windows Update running in the background?
I understand your doubt.
But one thing I always do on a fresh Windows install is go on Settings and into Control Panel to minutely configure everything, including disabling Windows Update / Advanced options / Delivery Optimization / Allow downloads from other PCs.
  • Aftwards running Chris Titus Tech and n1snt scripts to debloat and decrapify the OS.
  • Because Microsoft makes things dubious, I also go on that screen to Advanced Options and limit the snot out of that. Actually I never remembered after months of using an installation to check the stats, if it continues at 0. Since I re-installed W11, I can't now verify if that was it.
At the time, on Task Manager I consulted Processes ordering the Network column and then Details ordering by I/O reads or CPU column to try to figure which app was doing Uploads.
I couldn't. Hence this post...
  Reveal hidden contents
Thank you very much. And Wireshark has a *.paf.exe -- PortableApps version 🙂
That's perfect for having on the USB stick I've carrying around for decades (and I'm not exagerating).
Again, thank you!
