4070ti tuf using a 4x(6+2)8 pin connector
4 hours ago, Rhys0625 said:Good day everyone i need some advise I have a THERMALTAKE gf1 1000w PSU, according to the manual it has a 120watt output per pcie slot, so I bought a an 4 way pcie adapter for my tuf 4070ti GPU, is it ok to use this or would I over current my GPU, I'm not really familiar how the PSU works, so I worry of using this adapter, since I already bought the 4 way is it ok to use this or should I buy a new 3 way adapter thank you
The manual I found says 150W as that is the standard for PCIe 8pin.
https://www.thermaltake.com/toughpower-gf1-1000w-tt-premium-edition.html
What's the issue with the 2x8pin to 12vhpwr adapter that came with the 4070ti? 2x8pin(2x150W)+ pcie slot(75w) should be enough for the card(375w) since the gpu only consume ~300w.
https://www.techpowerup.com/review/asus-geforce-rtx-4070-ti-tuf/39.html
But to answer your question, no you can't supply to much wattage to the gpu, it draws as much as it needs. If you could overcurrent, you would either need to plug/unplug cables as load changes or run Furmark 24/7.
