So I just received all the parts for my new computer and decided to make a quick testbench on my motherboard box before installing everything. All I had plugged was my motherboard (Asus Z87-A ATX), my CPU, my CPU fan, my RAM and my graphic card (GTX 770). I connected everything to my power supply (EVGA NEX750B) but as I am a beginner I made a mistake and I plugged the VGA1 8 pin-connector in the CPU power 8 pin connector. When I opened it, everything worked for 2 seconds. Then, a crack noise and everything stopped. Also smoke came out of the power supply.
I just want to know if my other parts are ok. Or do I need to change all my parts that were connected?
https://linustechtips.com/topic/149193-plugged-wrong-cable-in-cpu-power/
You probably need to change your psu...
That shouldn't happen. Best if you try a different psu. Even a 300 Watt will do for a quick test boot without the 770.
Edit: How was that even possible, it looks like the connections have different forms ( round/square).
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
You sir have just made the #1 mistake in computer building. RMA your PSU.
It cracked because the pinout is different for the VGA and the CPU power plug, for example negative is where positive should be so in other words you screwed yourself over.
How did you even manage that? The EPS and PCI power 8pin connectors have different shapes!
It's really a gamble if anything else is broken or not. It really depends where the power went before the PSU cut out. Best case - just the PSU is fried. Worst case - EVERYTHING is dead.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
I don't have another power supply so I'll have to wait for the new one! But you think all my other parts are ok?
In my experience it's a crap shoot and you won't know for sure until you get the new PSU in.... Just a bad situation...
Intel i7-7770K | Asus Maximus X Hero  | EVGA GTX980 SuperClocked | 16GB Memory| Samsung 960 EVO M.2 | Corsair RM 750W | Dell 27" S2716DG main display | Dual Dell ST2320L 23" Secondary displays | Windows 10
Logitech G710+ Keyboard | Logitech G502 mouse | Kingston HyperX Cloud headset | Corsair H100i
Yes the CPU 8-pin power connector is made of two 4 pins connectors and the VGA1 is a 6+2 connector
Even I won't make that mistake when I build my first PC here very soon. You should have checked everything before you turned it on for the first time. All the cables are clearly labeled. Silly noob.
That PSU is either a piece of sh*t or older than me... Return it and buy a quality one and pray to God everything still works.
EDIT: It's an EVGA PSU right? They really fucked up if you managed to plug the VGA power into your mobo, right a letter of complaint!
Where do bad folks go when they die?
They don't go to heaven where the angels fly
They go to the lake of fire and fry, Won't see them again 'till the fourth of July
