Even I won't make that mistake when I build my first PC here very soon. You should have checked everything before you turned it on for the first time. All the cables are clearly labeled. Silly noob.
Not cool, dude. Don't talk down on the new guys!
We learn from our mistakes.
I don't think you can RMA. But try to Open it up and check the fuse. If that is blown, try to change it. Otherwise, :'( .
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
He made a mistake, everybody makes mistakes , that's how we learn. You sir should feel bad. Even linus broke a cpu pin & made a video while desperately trying to fix it.
OP, you should have paid more attention, i hope you've learned the lesson, keep us informed if your components are still okay or if they have fried
I don't see how he can think that VGA is somehow CPU.
OK other question. I took the 30 days RMA (my order is with NCIX). Are these parts going to be replace at no cost or did I just blew up 1000$?
Depends if NCIX finds this thread or not :D
