Was told it may be better to post my questions  here!
Budget (including currency):  < $3500 USD Pref,  can go high as 4k.
Country:  USA
Games, programs or workloads that it will be used for:  Gaming, Mostly MMO's. Have cyberpunk, but current PC don't play it well.
Other details First time going custom water cooling ( soft tubing) . Got the basics figured out just trying to iron it out, before I buy  next month.
Current only i7 7700k, with 2080 super
Current items so far... https://newegg.io/acc1933
I7-13700k
MSI pro z790a-wifi
Corsair vengeance RBG 32 (2x16) DDR 6200
Sesonce 850 80+plat (a bit overkill ya)
planning on  cable extensions from cable mod
CPU block: Hydro X Series XC8 RGB PRO CPU Water Block — JayzTwoCents Edition
Pump/res: CORSAIR Hydro X Series XD5 RGB Pump/Reservoir Combo
360 rad with -Corsair SP120 rgb elite performance
280 ran with Corsaid SP140
Caste: HYTE Y60
GPU: pending prices in a month
Wanted to do with 4070 TI, but does not seem like anyone makes blocks for them.
Maybe 3080ti range, would need a block as well.
SAMSUNG 980 PRO M.2 2280 1TB PCI-Express Gen 4.0 x4
SAMSUNG 980 PRO Heatsink M.2 2280 2TB PCI-Express 4.0 x4
*** fittings not listed, purchased 2nd hand
Questions I have, do the blocks and what not come with plugs, or do I need to get those separately?
For drain value. I would just need a 3 way splitter, then have one with a ball valve and plug?
Coolant: good ole question, water vs other stuff? What would I need with either, for stuff to add to it (anti xxx stuff) . I would like it colored liquid.
https://linustechtips.com/topic/1490424-first-water-cooling-build/
49 minutes ago, elwindace said:
I7-13700k
I'd advise dropping to a 13600K to save some $, no noticeable difference between it and the i7 in games.
Plugs? Often do to keep dust out, you then remove those and use fittings. They don't usually include fittings, you will need to buy those separately.
Yep, just make sure to put it at the lowest possible point in your loop.
I use EK Cryofuel Clear, I get the premix because it's easy. I wouldn't advise colored liquid as the dyes usually cause issues (y'know, dying things that shouldn't be, sometimes gumming up the loop - especially pastel coolants) and fade after a while. If you're dead set on it, I'd stick with EK Cryofuel and get one of the colored versions.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Thanks.  Can't figure out how to do those fancy quote replies  xD
  For the GPU. Think I found my answer in a old  Jayztwo cents video 7:05
   Looks like they come with it....
Assuming pump would be the same  since it had muiti ports
Will look into that CPU swap, thanks for that input.
Will look into the coolant you suggested.
Now just to figure out the GPU and water block combos. Hopefully prices come down a bit in the next few weeks.
You can highlight specific text and then click the "quote selection" popup that happens when you do so. Or quote the full post with the arrows underneath it (quote and multiquote if you hover over them, multiquote is for grabbing multiple posts).
Mouse: EVGA X17
1 hour ago, andrewmp6 said:
Colored coolant is a bad idea,It will stain all your clear parts of the loop or cause worse problems.Go clear coolant and use rgb lighting to add color to it.
I've never had EK coolants stain my clear plexi or acrylic parts, mind you i've never used yellow or red and they seem to be the worst for staining, mostly used blue and purple both transparent and pastel variants.
I've had staining/buildup on nickel blocks where there is minimal flow, next to orings or where the nickel is up against acrylic.
The only time i've had major staining was in a second system using some Thermaltake transparent green coolant, that stuff is horrible and stained pretty much every surface it touched.
Maybe checkout Bykski for a 4070 ti block, they currently have blocks for 5 different 4070 ti's
https://www.bykski.com/page86?product_category=210&brd=1
I don't trust ek nickel platting,I have seen it come off with standard known brand coolants.While any other brands nickel stays looking new with the same coolant.
Why? You can do much better than Hydro X pump/res for the money. They are cheap and plasticy for the price. You could do much better with say an Ultitube from Aquacompuer which is both much higher quality and much cheaper. Heatkiller is nice too, though admittedly a bit more of an industrial aesthetic.
Did you specifically want the J2C block? Otherwise I would say again that you could do much better performance wise for the money. Heatkiller IV Pro comes to mind. I've seen people gain double digit better temperatures in 12th and 13th gen parts switching off Corsair blocks to EK, Heatkiller and such. Optimus and TechN make good blocks as well, but have heard Optimus may not have the optimum (lol) mounting for LGA 1700.
You didn't specify rads, so I'll assume its Corsair again. Corsair radiators are rebrands of the Hardware Labs L-series radiators with a price markup and a sailboat logo slapped on. You'd be much better just buying the Hardware Labs Nemesis rads which are a step up and often the same price as these Corsair rads in the US. Alphacool is also good. Both rads are filthy out of the box, so remember to clean/prep the loop. The problem with these Techtubers is they never show this. Get a Mayhems Blitz Pro kit.
Quote
They don't come with fittings, no.
Yeah could do that for the drain valve and then try to have it at the lowest point in the loop.
Quote
First loop, I get it, but you'll soon learn colored coolant aint worth it. The opaque stuff/solids are a maintenance nightmare, not to mention they can be damaging to nickel plating over time.
Clear that's been dyed is better, but can stain components/tubing over time as well. Don't always but they can and often do.
If you do water, add biocide and inhibitor additives to them, but be careful what you use. Copper sulfate based additives and nickel don't always play nice and the nickel can stain. If you get a premix, definitely go for a clear. I will go against the grain of this thread and say avoid EK Cryofuel. For a history lesson, when it very first came out, it was a Mayhems rebrand of X1. At some point they switched suppliers and now nobody knows what it is. But I can say, since that switch, I've seen my fair share of problems with it gunning up people's loops, even the clear. Many don't have problems at all. I call it the EK standard operating procedure, you never know what you are going to get with them.
For clear premixes, I recommend Mayhems X1, Koolance 702, Aquacomputer DP Ultra, or ModMyMods Mod Water if you are in the US.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
