Need Some Help
Go to solution Solved by RONOTHAN##,
Using one is fine, the second one is more for marketing purposes than anything
Just now, Ericcy said:
does it matter which header I plug the cable into
Not really. Plus into whichever one is more convenient to. Technically the one closer to the CPU is more optimal, but the difference is so marginal that it really doesn't matter
https://linustechtips.com/topic/1489783-need-some-help/#findComment-15811799
