PC not booting. Please help.
Go to solution Solved by NorKris,
this is what i would do:
MB on non concuctive surface
connect PSU to the MB, nothing else
try to turn it on
like this just with the CPU in ofc
I built a PC this morning. Parts are:
Ryzen 9 7900x
Asus Strix X670e-a gaming wifi
2 x 16GB DDR5 @ 5200MHZ
700W PSU (Not my build so I don't know the exact model but I can confirm that it does work as it worked fine in the system it was powering before.)
Corsair H100i 240mm
WD SN850x 1TB
GTX 1050 ti.
I'm sure i've connected everything. The motherboard lights turn on when I switch on the PSU but it doesn't actually turn on. I just get nothing. No Mobo LEDs, no fans.
Going to take the mobo out of the case and test later.
But what else could I try?
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
https://linustechtips.com/topic/1489435-pc-not-booting-please-help/
Ryzen 9 7900x
Corsair H100i 240mm
WD SN850x 1TB
GTX 1050 ti.
Did you correctly connect the case's power button?  Try jumping the power with a screwdriver on the motherboard.
Tried that too. Nothing either
System
CPU: Ryzen 5 3600
try to turn it on
Okay, I'll try that.
Will It matter not having the cooler on it?
System
CPU: Ryzen 5 3600
Put the cooler on. If it works, put in ram in slot A2 and B2 on the motherboard.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Just now, NorKris said:
u can put it on.. but no it wont matter.. we are looking for  a start, so no ram, no fans
Okay
System
CPU: Ryzen 5 3600
What psu? If you cant identify then take a picture of its wattage table
Hook the board to a psu and put in only the cpu, yes put the cooler on incase it starts
If it doesnt start wiggle the 24 pin cause sometimes that likes to be sensitive and make the board not turn on in certain positions i guess? Idk what word to describe that properly
If it still doesnt start just rma and get a replacement
try to turn it on
Don't know what fixed it, but it's all working fine now.
Thanks very much
System
CPU: Ryzen 5 3600
