I'm fixing to build my first pc. My goto game is fallout 4. I plan on using an msi b450 motherboard and ryzen 5 5600 cpu. I know I shouldn't skimp on the gpu, but I don't need anything high-end. I have been looking at the rx 580 8gb gpu up to a 1050ti. What would you recommend for a gpu?
https://linustechtips.com/topic/1488877-build-help/
The RX 580 8gb is a lot faster than a 1050ti, in some games over double the performance. You need to give us a budget limit so we can look for a GPU in your price range.
https://linustechtips.com/topic/1488877-build-help/#findComment-15805444
I'm looking overall to stay under $800 for pc so I can afford other things like monitor, keyboard, mouse, and a controller. The mb and cpu I picked out is to limit bottle necking.
https://linustechtips.com/topic/1488877-build-help/#findComment-15805466
If you can get your hands on a used rx 580 8gb that would be a pretty good GPU.
https://linustechtips.com/topic/1488877-build-help/#findComment-15805471
I did find one on fb marketplace for $80, but I'm skeptical about buying from someone on there. There going for about $128 on Amazon. Is that a good price point?
https://linustechtips.com/topic/1488877-build-help/#findComment-15805490
-Moved to New Builds and Planning-
https://linustechtips.com/topic/1488877-build-help/#findComment-15805596
