Help me pick a Psu!
Go to solution Solved by quan289,
So the
Corsair
RM650 or the Supernova 750? G2
The Supernova 750w G2 is a better build, higher-end PSU.
You could stick with your FD Integra R2 for your build btw.
My upcoming build :
AMD fx 8320 8 core
Sapphire vapor x r9 290
Adata xpg v1.0 8gb
Custom water loop
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/148776-help-me-pick-a-psu/
a 750-800 Watt would suffice.
BTW just encase u dident know, the 8320 sits around 65-70* Celsius and draws a crap ton of power and thats at like idle.
I would go with the 6300, its a 6 core and its quite a bit colder
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1987712
Any 650W PSU from reputable source should do just fine with a nice amount of headroom.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1987734
750w and 800w are overkill for this, unless he plans to crossfire.
A 600w/650w will do nicely.
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1987742
I'm going to do a custom water loop for it
Current
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1987775
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1988010
LOL my OCed FX8320 can idle at 13C and gaming only goes to 46C.
it must be user error or bad cooler.
When 2 things meet each other, Quantum stuff happens.
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1988059
i dont have the 8320, Pistol from Tek Syndicate had it, and Logan said it was like a "little furnace" xD
Also explain to me how the cpu can be colder then room temperature :P (it cant)
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1988584
Me human, no PC, me no undestand how temp works....
but thats my temp, max is when i ran Prime95.
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1988751
agreed, my cpu says its 12* at idle, but think about it, it cant possibly be colder then room temp. Even the best water cooling, can only be as cold as the air that is passing through the rad.
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1989081
My upcoming build :
AMD fx 8320 8 core
Adata xpg v1.0 8gb
So far this is ~ 385W
Now, with the custom water loop you would need a pump (12V) ~ 23W
Total: 408W (excluding hdd, fans, dvd drive, ...)
So I recommend this PSU: Corsair 650W - RM650 CP-9020054-WW
     ~ Live Love Code ~
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1989233
Oh well if Logan said so...
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1990794
AMDs temperature sensors are completely incorrect. It's physically impossible to cool something below room temperature by blowing room temperature air at it. You can only cool something below room temperature if you have a source of cold colder than room temperature. It's also why you can't make something reach absolute zero. You'd need something colder than absolute zero in order to get something too absolute zero
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1990922
exactly :P
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-1992095
So the
Corsair
You could also consider Be Quiet! Most of their PSUs have not even 1 bad review. You could take a look at the Straight Power or Dark power series.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-2016146
i have a fractal design r2 integra 650W, can i use that until i can pay for the Corsair one? (2 6+2 connectors also)
Current
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-2016253
My upcoming build :
AMD fx 8320 8 core
Adata xpg v1.0 8gb
Custom water loop
Are you thinking of crossfire later on?
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-2016375
Awesome, that will save me a lot of money, thanks man
Current
https://linustechtips.com/topic/148776-help-me-pick-a-psu/#findComment-2016412
