I made a post on the build help forum and decided to come here for the next part of my upgrade. I have been using Thermaltake Verse N21 ATX since 2018. I was told the airflow on this is not so great  and would like to get a new one. Any suggestions for under $100
https://linustechtips.com/topic/1487413-need-help-picking-a-new-case/
Corsair 4000D Airflow is a pretty good one for the money. You might even get a 4000X RGB for that price range if you're sharp.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Corsair 4000D as mentioned is a solid choice but it's a basic b***h case - boringly popular. 😛
I would also suggest looking at the Fractal Design Focus 2, Fractal Meshify C, Fractal Pop Air, CoolerMaster NR600, Phanteks Eclipse P400A and Eclipse G360A, and the NZXT H5 Flow.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
