We need more info, this is usually asked under "new builds and planning."
7 minutes ago, Husnain3325 said:
Nvme 256GB
But I can already tell you that a 256GB drive is too small, even for a boot drive.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1486661-building-pc-for-gaming/#findComment-15788815
dont u have a 250gb boot drive in ur system 🤨
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1486661-building-pc-for-gaming/#findComment-15788818
And yeah OP, we need far more info than this still. Budget, location of purchase, and also the system's purpose.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1486661-building-pc-for-gaming/#findComment-15788827
I do and I strongly advise against getting 250GB boot drive, especially now in 2023. If it weren't for my tight budget that I had to stretch because of parts shortage in 2018, I'd borderline regret my choice but at least I had an excuse. Some 4 years of messing around with never having any space on boot, because despite my best efforts, a lot of software just defaults to C drive and won't install anywhere else. This adds up the more you use your PC and more install more and more stuff.
512GB is the bare minimum, especially if it's your only drive. My laptop has a 512GB SSD and that's enough space for what...? A single VM, once version of UE5, one or two projects and maybe a game or two adding up to a total of 40GB. Barely any new release is 40GB, many indie games even pushing like 10GB, 4 indie games isn't that many.
https://linustechtips.com/topic/1486661-building-pc-for-gaming/#findComment-15788982
