Anyone having problems with AMD 14.4?
amd drivers are always buggy just un install it and install a prior one
Specs
NVIDIA drivers are hardly ever buggy. :P
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
There are two versions of 14.4 according to this link http://support.amd.com/en-us/download/desktop?os=Windows%208.1%20-%2064
Maybe try the other one and see if the problem is resolved. If the problem persists then revert to a previous version that worked.
No, the second one is the latest beta that was released earlier, several people including me have video acceleration BSOD coming from atikmdag.
The post does not give details on what the problem actually is. For all I know the problem could be related to installing the driver.
The two drivers in the link are the same driver, however one has the component that was causing installation problems removed from the installation package.
Works perfectly for me (on Z77 chipset)!
A friend of mine has an AMD chipset and he had to do a recovery after installing, so......yeah good job on supporting your own hardware AMD. ;-)
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
i had problems like game getting stuck in between(during heavy intense or somewhat intense sequence) and the monitor goes blank then refresh itself & the vpro recovery error shows up! then i have to manually shutdown the game using task manager & start again :angry: dont know why
Really really angry ninja :ph34r:
Details separate people.
AMD drivers are buggy as shit, on Windows 8 you can't use skype and you can't watch Netflix cos the drivers are so buggy.
This is why is still have Windows 7.
Mine seems to be working fine, not had any problems.
Windows 8.1, latest beta drivers, and Skype works fine for me so far.
Only problem I'm having is the mouse getting stuck moving between monitors, but that's the windows update as far as I can tell.
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
Works perfectly fine for me and I was even able to overclock 80mhz further with latest beta afterburner, what are the issues you are facing?
Yeah I had BSOD in windows 7 from atikmdag, reverted to 13.12.
Same here, upon windows loading and getting to the login and then BAM, Garbled artifacted frozen crap all over the screen, restart and same thing... Exactly the same garbled pattern too...
Reverted to 13.12, fine and dandy.
Before I was on 14.4 I had on 14.2 and they were fine, but I knew 13.12 worked fine and I already had the installer so I went with those, and its been fine since.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
NVIDIA baby though lately I've had issues installing the last three drivers from them, I fresh install and I get a bluescreen everytime.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
AMD drivers are buggy as crap
I didn't know crap could be buggy. :P
yes only issue is, when I watch something on screen 1 and start a game on screen 2 my pc freezes for 30 secs. and then goes in and continues playing the movie/series.
My Rig: Intel 3770k with Corsair H100i pull, Asus Z98 pro , Corsair Vengeance 8GBx2 2100 mhz CL9, Galax HOF 1080 TI, 4 x OCZ Vertex 3 120 gig Raid 0, Corsair AX 850, Corsair Obsidian 650D
