Budget (including currency): $1k Us
Country: USA
Games, programs or workloads that it will be used for: Light video editing, but mostly gaming. I want to play Apex valorant overwatch at 120 fps+, spiderman, and Horizon zero dawn.
Other details: https://pcpartpicker.com/list/jn3FNc are some parts i was looking at, im wondering if the i5 will bottleneck a 3050, also will i need to buy a separate cooler and get a better psu.
https://linustechtips.com/topic/1485068-will-this-build-work/
You're way overspending on CPU, and that PSU is a bit sketch. Also, you're way overspending on case for an 800 build.
300 USD for a 3050 is also a waste in a world where the 6600XT and 6700XT exist.
Here's a cheaper, faster build:
PCPartPicker Part List: https://pcpartpicker.com/list/wjXPBj
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($129.99 @ Newegg)
Motherboard: ASRock B550M-HDV Micro ATX AM4 Motherboard  ($110.73 @ MemoryC)
Memory: Silicon Power SP016GBLFU320B22 16 GB (2 x 8 GB) DDR4-3200 CL22 Memory  ($37.99 @ Amazon)
Storage: Silicon Power A60 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($50.49 @ Newegg Sellers)
Video Card: MSI MECH 2X OC Radeon RX 6700 XT 12 GB Video Card  ($349.99 @ Newegg)
Case: Thermaltake Versa H17 MicroATX Mini Tower Case  ($44.99 @ Amazon)
Power Supply: Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply  ($59.99 @ Amazon)
Total: $784.17
Generated by PCPartPicker 2023-01-30 21:06 EST-0500
Here's a MUCH faster build within your original 1K budget (enable PBO on that board to get more from that CPU).
PCPartPicker Part List: https://pcpartpicker.com/list/d4D2cb
CPU Cooler: be quiet! Pure Rock 2 Black CPU Cooler  ($44.90 @ B&H)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  ($119.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($48.99 @ Amazon)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6800 16 GB Video Card  ($479.99 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case  ($64.98 @ Newegg)
Total: $999.32
Generated by PCPartPicker 2023-01-30 21:09 EST-0500
Feel free to get more storage if you feel you can do without that aftermarket cooler for example.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/1485068-will-this-build-work/#findComment-15777321
Country: USA
Hello, I came up with this. It's all current gen Intel and is upgragde-able. I went with an AMD GPU because it's better than the 3050 and it costs less. If you ever wanted to get a better one the PSU I picked has room for it.
https://pcpartpicker.com/list/dq3b9r
PCPartPicker Part List: https://pcpartpicker.com/list/dq3b9r
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($209.98 @ Newegg)
CPU Cooler: ID-COOLING SE-914-XT 45.8 CFM CPU Cooler  ($26.99 @ Amazon)
Motherboard: MSI PRO B760M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  ($169.00 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($58.99 @ Newegg)
Storage: MSI SPATIUM M450 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($59.99 @ Newegg)
Video Card: XFX Speedster SWFT 210 Radeon RX 6600 XT 8 GB Video Card  ($299.99 @ Amazon)
Case: Antec NX410 ATX Mid Tower Case  ($85.49 @ Amazon)
Power Supply: Enermax Revolution D.F. 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($82.99 @ Walmart)
Total: $993.42
Generated by PCPartPicker 2023-01-30 21:23 EST-0500
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1485068-will-this-build-work/#findComment-15777342
