Raspberry Pi 4 not connecting to WiFi after connecting to ethernet.
I have a problem with my Raspberry PI 4b of it not connecting to the internet through wireless. I was trying to run a Minecraft server on my raspberry pi and needed as fast of an internet connection as possible. I connected directly to the ethernet port with a cable from the touter.
Now when I unplugged the ethernet cable the Pi keeps trying to connect to the home WIFI, but when I check on the connecting process by hovering over the WIFI indicator, the little popup tag says "associated with (my home WIFI name here)", and it will never stop saying that.
Can anyone suggest possible fixes other than reinstalling the OS?  I'd like to fix the issue without having to reinstall the OS for a variety of reasons.  The WIFI worked fine before I plugged in the Ethernet cable and then it hasn't worked since.
Thanks!
Delete your wireless newtwork settings from /etc/wpa_supplicant/wpa_supplicant.conf
In terminal run this command
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Delete the section that looks like this
network={
ssid="your network name"
psk="your netword password"
Once done either restart the pi or try restarting the network service
sudo service networking restart
You should now be able to reconfigure the wifi from the desktop
 Share
