Moving drive form one pc to another [help]
Hello everyone,
I need some help i moved my main ssd form one pc to another where i already have all my steam games installed. How do i have my new pc see that i alreadyt have all my games installed so i dont have to install tham again.
Thanks.
Is the drive able to be seen by the new PC?
If tape can't fix it, nothing can.
1 hour ago, Two guys One kite said:
yes
If you add the Steam folder to your library, it should automatically detect all your games. If it doesn't, you'll have to add them manually. It should go through a verification process since it detected pre-existing files.
Edited by Godlygamer23
  • 2 weeks later...
You should be able to go to settings and create a new steam library folder. I think it should accept your already existing folder and work right away. If not try creating a new library and move all of the games in there, that might work
 Share
