Wi fi help
Solved by Queen Chrysalis,
An ac1200 will be fine, but what kind of motherboard do you have? Some of them have an m.2 wifi port (slightly different from an m.2 ssd port) that can take a small m.2 chip. The intel AX200 does wifi 6 and Bluetooth 5.2 and usually costs less than PCIe cards.
Otherwise, an ac1200 unit will be fine. Your router is probably good too (aside from it being produced by a global IP thief). I would use it and see how it is before you buy a new one.
