Case Fans Should Monitor Motherboard or CPU?
TL:DR: CPU is faster, but mainboard is more accurate.
It really depends on your configuration. Judging from your signature, you do have a rather modest TDP cpu with a very powerful cooler and a well ventilated case. In such a scenario, the CPU cooler is able to keep the processor in check without case fans. If it heats up more than typically, it is the result of increased case temperature caused by concurrent GPU activity - That's when you need your case fans to ramp up.
So, setting the case fans to ramp up ~5° later than the CPU fan should yield you almost ideal results and very fast reaction time. Your CPU Fan should reach full speed at 70°C, your case fans at 75-80°C based on your target noise level.
And if you want to go crazy, I can only recommend "Speedfan". It is a software tool to run very complex fan settings based on multiple temperature reads. While a pain to set up, it is able to give you the best cooling control. If you want to go this road and need support, I'm happy to help
But honestly, just using CPU will probably give you 95% optimal results with your cooler/case.
