tweaking and power limits of a CPU
Solved by RONOTHAN##,
Uncore is the frequency at which the CPU can access the cache and other cores, it in itself shouldn't really affect power draw much, if at all. You can do a bit of testing, but unless you're raising voltages like the System Agent (what the Uncore runs on) the only power consumption increases will be from the CPU running more efficiently per clock which should be well under a watt at most.聽
Featured Topics
WolfOfValhalla 路
Posted in Cooling0 -
FireLegend 路
Posted in Troubleshooting3 -
2
1
6
UnRaidLegends 路
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin 路
Posted in Displays2
