CPU Cooler for Ryzen 7 - 5800X. Is the ARCTIC Freezer 34 eSports DUO any good?
Solved by Zonal,
Either one will work great! They will probably end up being somewhat similar in noise and temps. I’d personally probably go with the be quiet as it is probably going to be easier to install, quieter, and cheaper. I would advise that aios usually are quieter in terms of decibels but often have an annoying whining noise of the pump, air coolers shouldn’t have any whine but may spin slightly faster. Depends on what you’d rather deal with, or what you prefer in terms of aesthetics. Otherwise, if you’d like something a little cheaper I’d recommend the as500 plus. It’s not far off from either of those in temps but you can save $40.
