Can a monitor be powered from the psu using usb-c pd?
Androkistis
I'm looking a getting a used LG 22M38D-B 21..5 which comes with an external power brick. I've seen usb-c to barrel adapters and also watched the LTT video on powering "anything" with ubs-c.
Can the power from a psu be converted to usb-c pd at a high enough wattage to power a monitor? My reasoning is to create a "portable" monitor which can be powered off of my "portable" pc.
Your motherboard USB-C ports will probably not be able to provide enough power.
However, you could definitely DIY a Molex to USB-C power adapter - I've done that with USB-B and barrel connectors a few times to power displays and adapters.
Why not just get a USB powered monitor?
https://www.amazon.com/s?k=usb+powqeredmonitor&crid=1K4KXTI1R82C9&sprefix=usb+powqeredmonitor%2Caps%2C90&ref=nb_sb_noss
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I think you can technically with Asus boards they have 65W PD on usb C only the higher end ones. and i think youre just better of with buying an power cable for your monitor or somethink like Portable power bank or even a portable monitor (their is 500 of those)  they come with usb C PD. But how you are going to power the Pc anyways ? . Btw this is a thing in old office Pcs but not USB C of course its just anoher Powerplug
Probably should have mentioned that the pc is an old parts build so I'm wanting to do like what MelOn said, molex to usb-c just not sure how.
Monitor lists 18-25w 19v 1.2a
I know I could buy a usb-c powered monitor, but that would cost over $100 for a decent one. The one I'm looking at is used and cheap.
The PC will be powered normally, this is just to eliminate the long power cable to a plug. I'm working to make this thing easy to move around by eliminating or shortening all cables it needs. The computer is being built into a custom case to make it easier to move.
Kinda makes no sense, you'd have to convert 12V from PSU to 19V, implement a USB-C source (not trivial), only to then convert it from USB-C back to barrel at the other end.
Forget all the USB-C, get a step up converter that makes 19V from 12 and feed that directly.
F@H
GPD Win 2
